New Case, AIO & Fans Please HELP
45 minutes ago, RevGAM said:I'm here to help. Sorry you feel that way but I'm not assuming you don't know anything. Quite the contrary. The info you gave showed that you're not a novice, but you also didn't give certain info that would help us to better serve you. Advice given in advance to cover the bases.
The only mistake I made was thinking the FireCudas were HDDs. I didn't ask you about them, not sure what gave you that impression - I just made a recommendation based on my mistake started above.
It seems you are, as I suspected, doing very heavy work, which is why I mentioned Tech Notice as a resource. Only that kind of heavy load would cause an AIO to burn out so fast. I'm not sure that Arctic is the best choice, but at least they have a great warranty. However, if you get much stronger fans, you will have much better results from that AIO because of some design... imperfections.
If your idle is that high, what are your temps during full load? Please give us a screenshot showing all temps and watts.
Do you still want advice?
I'll give you one more thing. Since you didn't indicate that you've repaste, which would be required routinely with most TIMs given the 24-hr schedule, either
- get a phase-change TIM like Honeywell PTM7950, or
- get a permanent solution like Thermal Grizzly Kryosheet.
Both are excellent products. The former will not last forever, but it will last longer than most TIMs AFAIK. The latter will last virtually forever, but it is electrically conductive, so be careful.
Thanks for clarifying, and I appreciate the help.
I should have mentioned earlier that I primarily use this PC for very intensive tasks like virtual productions using vMix and 4K video editing. These activities demand high performance, which is why I'm keen on maintaining optimal temperatures.
Regarding the FireCudas, my setup only includes these SSDs as I avoid mechanical drives due to their limitations in high-performance scenarios.
To give you a better idea, the idle temperatures are currently hitting 50-60°C, and under full load, they spike to 100c.
I have had a failing AIO before and its exactly behaving the same. Going for a warranty again its a painful process that takes weeks.
Repasting was done multiple times in the past 6 months. i Keep maintenance on this computer every 2 months - Full format and Dust/Repaste.
I have purchased the following for Maxing Out my z690 Board to the limit and give this computer another 5 years or more of Life in the High Specs Performances with the 3090.
