Hey guys , i bulit custom pc on my own and just wanted to check if everythings alright , sometimes i get blue screens when i play for to long and some times i get fps isssues too . i have a gigabye aero rtx 4080 super oc and i have ryzen 7 7800 x 3d , 32gb ddr5 ram  1tb m.2 sdd (boot drive) then a 2 tb m.2 secondary storage and 1000 watt power supply . most of the time pc feels like its not starting the way i would like to , it boots up its good but i run 3d benchmark and on average im getting 63 fps . i have autooverclocking on my amd ryzen master app but it dosent seem like its truly on because i have to restart my pc everytime... and i know this true beacuse i do 3d benchmark after the restart and i getting around 75to 80fps .  so i kinda just wanna know what going if everything seems okay .
https://linustechtips.com/topic/1570299-need-pc-help/
What do the Windows crash logs say?
Please use the mark as solution feature if your query was resolved.
If multiple people people contributed to a solution, pick the most helpful contribution.
https://pcpartpicker.com/list/TM4Hyg
https://linustechtips.com/topic/1570299-need-pc-help/#findComment-16409490
What speed are you running the RAM at, and is it 2x16, or 4x8?
https://linustechtips.com/topic/1570299-need-pc-help/#findComment-16409496
