2 hours ago, NukoTi said:
does anyone know sidebutton Replacement for the pulsar xlite v2? after i accidentally dropped the mouse the back button stopped working completely. and
i cant seem to find what button they used here
Can you give me a pic of what it looks like behind those switch ?
So far it looks proprietary as F or at the very least hard to find type.
edit :
https://www.aliexpress.us/item/3256805732607352.html?src=google&afSmartRedirect=y&gatewayAdapt=glo2usa
The H16.8 one, same brand, which is MWK
Edited by Poinkachu
Refresh before you reply
https://linustechtips.com/topic/1570185-sidebutton-replacement/#findComment-16408263
7 hours ago, NukoTi said:
thank you so much! but apparently wd40 fixed it somehow, probably a temporary fix. but thanks again this is very awesome
Uh... I'd clean it well using IPA if I were you.
WD-40 will leave a thin layer of oil that will be a dust and grime magnet.
Unless you meant Residue Free Contact Cleaner made by WD-40 instead of regular lubricant WD-40
Also, in case you don't know ;
If you don't quote using the reply button at the bottom of their post image.png.888c8ecbf2ed4e0767111f3c0ea0601d.png, or tag people's name like this @NukoTi
Most of the time people wouldn't know that you've replied, I just revisited this thread of yours again by accident this time. 😬
https://linustechtips.com/topic/1570185-sidebutton-replacement/#findComment-16408664
