Hi i Was updating my motherboard. After i instaled the updates i neded to re start my pc. I did, but my pc never did get on. IT never showed the BIOS Just went strait to a problem. Windows faild to start. I now have delited the Windows file from my C drive and re instald IT. But same problem. Is the motherboard broken?
https://linustechtips.com/topic/156921-motherboard-problems/
maybe try updating the bios ? also look into the sata configuration
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/156921-motherboard-problems/#findComment-2091871
just thought id point out you spelled design wrong on your system specs thing :)
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/156921-motherboard-problems/#findComment-2091966
I am not 100% certain but if you still have your motherboard's manual (which after 2 years might not be) there may be a way to flash a new bios.
THX!!!!!!!!! you saved my. i did jump i conector and it did work. i did have tha manual i did not think of loking in it. THX!!!!!
my Babe is working :D :D :D :D :D :D
https://linustechtips.com/topic/156921-motherboard-problems/#findComment-2092041
