Hello,
I have a mother board named SDK0J40700 WIN
and was wondering which CPU would be compatible with it and what I should upgrade to.
Currently i have:
Intel Core  i5-9400F CPU @ 2.90GHz
16gb RAM
NVIDIA Geforce RTX 2060
Does anyone recommend that I upgrade anything else or should I just buy a brand new PC?
The reason to the post is that newer games requires more and i want to enjoy the games without any lags or crashes.
Any tips or advice would be appreciated
Thanks!
https://linustechtips.com/topic/1568122-pc-advice/
which games are you playing at what resolution? I'd say a new pc if you've got the budget for it
16gb RAM
full specs? (Storage, PSU, Case etc.)
the only ones that are compatible aren't really a worthwhile upgrade for the money
Edited by filpo
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1568122-pc-advice/#findComment-16391397
I advice against getting a 9th gen cpu as the only good one left is the 9900k which is stupid expensive for what it is.
I'd say at least platform swap so board cpu and potentially ram.
What are the rest of yoru specs?
Psu in detail please.
Is this perhaps a prebuilt?
https://linustechtips.com/topic/1568122-pc-advice/#findComment-16391398
On 4/25/2024 at 9:29 PM, Jafari said:
Hello,
Currently i have:
16gb RAM
Thanks!
Id say upgrade ya gpu maybe step up the ram to 32gb
https://linustechtips.com/topic/1568122-pc-advice/#findComment-16392261
