So i am doing a 100% gaming rig in a corsair 750D. I have decided to go with a corsair h100i liquid cooler for my cpu and a corsair h105 + a kraken g10 for my gpu (a gtx 780). My questions are; what exactly is push pull air flow, do i need it, how many fans would i need, and can it all fit in the 750D. I am going for the most budget fan set up.... THANKS
https://linustechtips.com/topic/156808-help-with-push-pull-cooling/
This is push/Pull.
For an H100 you'd need 4 fans to achieve it because it's 240mm and can mount 2 fans on each side, the kraken is only 120mm so would require 2 fans.
For an H100i, if you use decent fans then I'd say no, you don't need it, 2 fans 'pushing' will be fine, as for the 780 idea, I wouldn't be doing that in the first place but 1 fan is probably going to do it ok there.
Suggest pair of Noctua NF-F12s for the H100i :)
Why did you post this twice?
- "some salty pretzel bun fanboy" ~ @helping, 2014
- "Oh shit, watch out guys, we got a hopscotch bassass here..." ~ @vinyldash303
- "Yes the 8990 is more fater than the 4820K and as you can see this specific Video card comes with 6GB" ~ Alienware 2014
