Awful noise through JBL LSR305
Solved by Sandbass,
If the information I've found online is correct, your old speakers didn't use a grounded power cord. The 305 do, so that's one of the reasons they could behave differently.
The second reason is your incredibly janky sounding solution to connect the speakers to your pc. If you can't spend the money for a halfway decent audio interface (which you absolutely should for using studio monitors), get at least the best quality proper cable (3.5mm TRS to 2x 6.3mm TS) - preferably somewhere you can return it, if this doesn't fix your issue.
You can also find hum eliminators for unbalanced connections, but if you're going this far, just spend the money for an used Focusrite/Presonus/whatever
