So, I want to have my pc in one room and be able to bring my monitor and mouse and keyboard and my wired controller into another room and be able to use the pc without having to move it.
I don't have a thunderbolt 3 port but I do have a usb c port on the motherboard.
Is there a hub or a solution that I can use. I looked it up and there's usbc hubs but they have short fixed cables.
They don't seem to make 50ft usbc cables.
Here is my motherboard, if this helps.
https://rog.asus.com/us/motherboards/rog-strix/rog-strix-b550-f-gaming-wifi-ii-model/.
Thanks
CPU: Ryzen 7 9800x3D
CPU Cooler: Arctic Liquid Freezer III Pro 360
Motherboard: Asus Tuf b650e-e wifi
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
Storage: TEAMGROUP T-Force Cardea Z44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: Sapphire Pulse 9070
Case: Phanteks Eclipse G360A ATX Mid Tower Case
Power Supply: Super Flower Leadex III Gold UP 850 WW
Monitor: LG 27GN800-B 27.0" 2560 x 1440 144 Hz Monitor
https://linustechtips.com/topic/1567704-usbc-hub/
they do make 50ft usb-c cables, but they have to be active ones, meaning the cable itself has hardware at each end. And even then 50ft is right at the limit.
you would be better off going with a fiber optic usb-c cable
they do not do displayport at this length, so you would have to buy and run one 15 meter usb-c and one 15 meter displayport cable. Then any usb-c hub would work for just peripherals
though that's like at least $250 in cables
https://linustechtips.com/topic/1567704-usbc-hub/#findComment-16388495
