What Power Supply I need for a ASROCK B450 Pro4?
Ernand
This weekend I got a few PC parts from my neighbor who was moving out, In those parts I acquired an almost complete PC rig. (CPU Ryzer 5 3600x, Mobo  ASROCK B450 Pro4, Ram 16Gb, AIO cooler, fans)
The one thing missing is a Power Supply, SSD, and a GPU.
I tried to look online, but I am not sure what Wattage of PSU I should get.
I want to get one with enough head space for a GPU in the future, but I do not want to buy a 1000W, if I will just ever need 650W.
I do not plan to overclock this thing.
Any recommendation as to the minimum wattage I would need?
Here is a Photo of the parts I got
i-found-this-in-the-trash-is-salvageable-v0-11pmkjow0ivc1.jpeg?auto=webp&s=68458110045412097e5f967cc78a8f6fbb10f610
6 minutes ago, Ernand said:
This weekend I got a few PC parts from my neighbor who was moving out, In those parts I acquired an almost complete PC rig. (Mobo, Ram, AIO cooler, fans)
It all depends on your CPU and GPU that you want.  A solid 650w will go a long way and 750w will give some overhead.
I run a Ryzen 7700x with overclocked RTX 4080 on a 750w and could easily run it on a 650w as well.
What CPU did you get?
You get a PSU based on the CPU/GPU, not the motherboard.
Finalize the build, selecting PSU last based on all other parts.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
It seems to be a Ryzen 5 3600x
And I might either get a 1060 or a 3060, which ever comes first and cheaper.
a solid 550w - 650w will do plenty for that 🙂  Get a 650w for a little headroom.
The MSI MAG A650BN is decent with a 5 year warranty. Budget friendly price.
https://pcpartpicker.com/product/8LNxFT/msi-mag-a-bn-650-w-80-bronze-certified-atx-power-supply-mag-a650bn
Well the 1060 will be cheaper, as it's old and weak (relatively).
Don't buy it.  Find out your budget and then look at what you can get.
OnePlus:
Other Tech:
Thanks, for now, I will use my old Radeon R9 360 OEM.
I think that is less than 400W total, right?
I think a 650W will be good for an upgrade, and I might get a 750W if is on sale.
I assume a 850W would be overkill?
