How significant is Nvidia low reflex?
Go to solution Solved by jaslion,
Extremely minor for both amd and nvidia.
Are you a top 0.000001% ultra mega pro gamer deluxe supreme street fighter alpha zero max cheese kawabunga gamer?
If the answer is no then well it don matter one bit.
Its mostly marketing really and making big numbers look important or oh no your pc is so much worse by now being 0.02ms slower (something you need a very high speed cam to even just see the difference). Some blind tests have been done people dont notice. Except in one game but forgot what that was as it was a technical issue where there was a bunch of input lag unless you turned on one of these features for some reason.
I do play a couple of competitive games and i thought Nvidia's low reflex might affect my buying choices. I was planning to get an rx 6800, but after hearing about low reflex and how it is much better than amd's anti-lag, i started to wonder if i should go team green. Apparently low reflex gets rid of the rendering queue to reduce latency, but if i have a mid range gpu like the 6800 will that be a significant latency decrease?
https://linustechtips.com/topic/1566765-how-significant-is-nvidia-low-reflex/
AMD also has AntiLag and AntiLag+ but limiting the framerate without having a CPU bottleneck causing stutters is still the best option.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
