Given a PC with no hard drives but everything else intact, how to get it running?
Solved by Dutch_Master,
For starters, boot a Linux Live CD-R to see what's actually in the system. You don't need a harddrive for that. Next, install the system-OS SSD from your old system and see if it recognises your new PC components. After that, just add more drives. It's likely your data can (and will) be reused. As for the licence key, accept a test licence for now and upgrade to a new key once you've obtained that.
聽
Or install Linux outright, no paid-for S/W key required
