Cooler help
Solved by DoctorNick,
8 minutes ago, EdOrange said:That weird, i'll try again.
Its fine, and very normal for a lot of coolers. The cores are in the middle anyways:
What temps you getting? That CPU isn't very hot if I remember correctly
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
