Motherboard or cpu issue?
7 hours ago, Cramig88 said:Looked up the cha341 thing, appears to be a usb dongle of sorts - simple explanation that is
i can’t force flash under standard USB as they don’t do anything but power output
you connect it to a laptop or something and use some female - female jumper wires to hook it up to that unmarked spi header i mentioned, thats how you reflash
7 hours ago, Cramig88 said:Suppose I need a UART flasher (non usb, manual). Prior to that whip out the voltmeter and see if there’s trouble, one “pin” to ground at a time
and how would you go about flashing via uart anyways? like what the hell header is that thing supposed to connect to? never really looked into uart
i would have probably reccomended desoldering aswell but these new bios chips arent sop8 and i have no idea how you desolder them nor what adapter board fits them
