Hi all! I'm building my first ever PC and would appreciate feedback. This is what I've got so far: https://au.pcpartpicker.com/list/rY4bz6 . My budget is around $2000 AUD and I'm mainly going to use this PC to play games such as Valorant, Overwatch, and Genshin Impact. I'm not too concerned about the aesthetics and instead would much rather like a high performing PC that could run these games (especially the FPS ones) at around 200 fps. Thanks in advance!
https://linustechtips.com/topic/1565288-first-pc-build/
This’ll be infinitely better
PCPartPicker Part List: https://au.pcpartpicker.com/list/dV3xdH
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($308.00 @ Centre Com)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($49.00 @ Scorptec)
Motherboard: Gigabyte B650 UD AC ATX AM5 Motherboard  ($259.00 @ MSY Technology)
Memory: Lexar Ares RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  ($158.00 @ Mwave Australia)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($169.00 @ Mwave Australia)
Video Card: PowerColor Fighter OC Radeon RX 7900 GRE 16 GB Video Card  ($929.00 @ PCCaseGear)
Case: Montech X3 Mesh ATX Mid Tower Case  ($79.00 @ PCCaseGear)
Power Supply: Corsair CX (2023) 750 W 80+ Bronze Certified ATX Power Supply  ($99.00 @ Centre Com)
Total: $2050.00
Generated by PCPartPicker 2024-04-03 22:26 AEDT+1100
https://linustechtips.com/topic/1565288-first-pc-build/#findComment-16370610
Total: $2050.00
https://au.pcpartpicker.com/list/BJfWL9
basically just 7600 -> 7700 whilst downsizing to matx so its smaller and takes up less space
if you wanna cheap out on the psu the proper way to do it is to buy used since you can probably get a 750/850w rm(x) or equivalent for the same price as the pk650d in my list which will be far more futureproof due to the extra wattage and give you a slightly cheaper power bill, but if you wanna stick to new (no reason to do so except convenience or used psus being overpriced for some reason or unavailable) just get the cheapest half decent thing available and be done with it
nvme swapped for a cheaper dram gen3, dram gen3 > lowend dramless gen4
ditched the cooler since the included wraith prism will be more than enough to cool a 7700 even if you tune it abit with pbo or a manual allcore oc
also dont forget to mention 6400 will default to desync uclk or whatevers the terminology for am5 so itll be much slower than 6000, most chips should be able to do 6200-6400 with a little bit of tuning but id just reccomend manually setting 6000 after enabling xmp so no further tuning is required, 6400c32 is an a die bin so no need to swap rams in the future unless you need more than 32gb or future cpus somehow break well past the 10000 barrier (plausible for apus since theyre already doing near 11000 but dunno why youd wanna run em with a discrete gpu)
https://linustechtips.com/topic/1565288-first-pc-build/#findComment-16370654
Hello... I made you a Build List and this PC will pretty much be the best you can get for your Budget. Inside will be a Ryzen 7 5700X3D and a RX 7800 XT 16GB GPU. It also has 32GB of RAM and the whole PC has no RGB, this is what I call a "Blackout" PC. 2TB M.2 Storage and a Fan Pack. The Case only comes with 1 Fan so I added 3 more for you to put in the Front of the Case, they Daisy-Chain together so it only takes up 1 Fan Port on the Motherboard.
I am happy to answer any questions you might have. Please let me know what you think. I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://au.pcpartpicker.com/list/2tbF9c
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($379.00 @ Centre Com)
CPU Cooler: Cooler Master MasterLiquid 240L Core 71.93 CFM Liquid CPU Cooler  ($89.00 @ JW Computers)
Motherboard: Asus TUF GAMING B550M-PLUS WIFI II Micro ATX AM4 Motherboard  ($199.00 @ MSY Technology)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($105.00 @ BPC Technology)
Storage: Lexar NM790 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($175.00 @ Mwave Australia)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  ($799.00 @ MSY Technology)
Case: Deepcool CH370 MicroATX Mid Tower Case  ($88.00 @ JW Computers)
Power Supply: Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($135.00 @ Mwave Australia)
Case Fan: Thermalright TL-C12C X3 66.17 CFM 120 mm Fans 3-Pack  ($30.75 @ Amazon Australia)
Total: $1999.75
https://linustechtips.com/topic/1565288-first-pc-build/#findComment-16372436
