bottleneck Is there a way to know how much bottleneck I might get?
1 minute ago, Millios said:I do understand the concept of bottleneck and cause it might hinder me for future jobs ill need the PC for im asking. Cause i have worked with and will likely work with Files and programms where 2K or 4K resolution will be needed as well as high FPS
If we're talking about gaming where this matters at all, this reply enforces the point that you don't really fully grasp the concept. There is always a bottleneck in performance. If you're getting 160fps, there is something preventing you from achieving 161fps. If you had no bottleneck, fps in games would be unlimited.
What you want to shoot for is for that bottleneck to not be the CPU, otherwise your GPU can't get data fast enough to work to its full potential.
You have a 4060 listed and it doesn't take a ton to fully support that. A Ryzen 7600 is the latest generation (at least until later this year with Ryzen 9000) and won't be a problem in nearly any titles at 1440p and 4K.
Now, if you moved to a 4090 and were for some reason still using a 1080p display, that would pose a problem.
