deepcool question
Go to solution Solved by TatamiMatt,
13 minutes ago, Aussie_Avo said:
Like if I upgrade the cpu I wouldn’t have thermal throttling
Most air coolers can do that, the only ones youll have issue cooling with an air cooler are the 13th and 14th gen i9s
Regardless, id get an Arctic LF3, best bang for buck currently
2 minutes ago, Aussie_Avo said:
should i get the Deepcool LT520 Premium Liquid CPU Cooler or Deepcool LD240 CPU Cooler
What are you trying to cool?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1564696-deepcool-question/#findComment-16366517
Just now, Aussie_Avo said:
a 12400f...
Do you want an AIO? That cpu can be easily cooled with an air cooler?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1564696-deepcool-question/#findComment-16366524
14 minutes ago, Aussie_Avo said:
Yeah I want a good upgrade path
What? Thats not how that works, could you explain what you mean?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1564696-deepcool-question/#findComment-16366556
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1564696-deepcool-question/#findComment-16366577
Ok thx!
Specifically, a thermalright phantom spirit, beats NH-D15 and a lot of 240mm AIOs for $35-40, if you want to spend about $45 you can get the phantom spirit evo with upgraded fans, currently, imo, one of the best looking and best performing coolers on the market
For AIO, Arctic LF3
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1564696-deepcool-question/#findComment-16366589
For the record, prices tend to drop over time. Unless you are sniping a huge deal you're just wasting money.
https://linustechtips.com/topic/1564696-deepcool-question/#findComment-16366615
