Need help with cpu
nope i dont think a day or 2 is enough to even degrade it, i assume <100c? in that case you arent even running over tjmax so even in 10+ years it would have experienced next to no degradation
if you were running more like 130c maybe degradation would be plausible but even then i doubt itd be noticable unless it was running at 130c constantly and im pretty sure thermal shutdown happens at around 115c atleast if you didnt manually disable or raise the thermal shutdown temp, no idea what temp will cause instant death to the cpu if powered on since noones bothered to test this but id assume somewhere well over 130c, powered off itll easily handle 200c+ for soldering the ihs
and with said high temps you wouldnt really be able to push any real voltage into the cpu even if you tried overclocking the thing
so yeah no worries here just enjoy your pc
