How do I fix this? there's a literal stream of micro bubbles. Temps seem ok but i know they could be better. I'm at 25-30 cpu idle, 25-35 gpu idle, 40-55 cpu heavy load, 40-60 gpu heavy load. Cpu is 12700k oc to 5.0, gpu is 3080 oc +75 core +115 memory. iv bled it checked concentration, ph around 9.
https://linustechtips.com/topic/1563990-first-custom-loop-micro-bubble-stream/
Did you install a port to bleed air out?
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Not uncommon in new loops. Takes usually a week or 2 in most cases, but can be longer, to work them all out. Best way is to constantly cycle pump speeds to collect and push the air through. Tipping gently side to side as well helps move the trapped air out.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
