Hey so I'm planning on getting liquid cooling for my setup soon, what's the risk of leakage with an aio, and what do u guys reccomend? Perferably one with argb, 360mm. I have a budget of about 150$
System Specs:
CPU: AMD Ryzen 7 5800x 8-Core Processor
Memory: 32 GB G.Skill Trident Z DDR4
SSD: WD_BLACK SN770 1TB
GPU: Nvidia GeForce RTX 3060 12G oc
Motherboard: Asus Prime B-450 A2
Case: MuseTex k2 Mid Tower
Monitor: Samsung SyncMaster S27D360
Keyboard: Razer Onata
Mouse: Razer Viper
聽Other cool tech:
Ender 5 pro 3d printer
Dji mini 3
Flight hotas x52
Fender Squire SSH stratocaster
Positive grid spark 40w amp
https://linustechtips.com/topic/1563393-liquid-cooling/
Risk of leakage is really minimal with an AIO, it's more of an issue when you make a DYI loop, believe me 馃檪!!
Get an Arctic Freezer III 360, it's around that price and the best AIO around !
AMD R9聽 7950X3D CPU/ Asus ROG STRIX X670E-E board/ 2x32GB G-Skill Trident Z Neo 6000CL30 RAM /聽ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /聽 Arctic Liquid Freezer III 360 ARGB cooler/ 2TB WD SN850 NVme + 2TB Crucial T500 NVme聽 + 4TB Toshiba X300 HDD / Corsair RM850x PSU/ Alienware AW3420DW 34"120Hz聽3440x1440p monitor / ASUS ROG AZOTH keyboard/ Logitech G PRO X Superlight聽mouse / Audeze Maxwell聽headphones
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16356717
Alr is the asus rog strix cpu cooler any good? I was looking at that one, and its also in my budget
System Specs:
Mouse: Razer Viper
聽Other cool tech:
Dji mini 3
Flight hotas x52
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16356752
It's almost certainly overpriced, and definitely worse than the Arctic because the Arctic Freezer III is the best 馃檪
Not my opinion, facts :聽
Really don't buy "brands" for cooling, they don't make that themselves but get them made for them and charge +40%
Otoh Arctic is definitely a cooling specialist (like Noctua, BeQuiet, EK, LianLi..)
Corsair is a bit different, they do their stuff but they just aren't very good at cooling, their thing is RGB and innovative connectors聽馃槢
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16357016
Well this was the one i was gonna get聽https://tinyurl.com/yuhn9jw4
System Specs:
Mouse: Razer Viper
聽Other cool tech:
Dji mini 3
Flight hotas x52
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16357399
Price is ok, seems to preform decently but noisy with meh fans...
What's wrong with the Freezer III ?
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16357448
I was hoping for one with argb to match my case
System Specs:
Mouse: Razer Viper
聽Other cool tech:
Dji mini 3
Flight hotas x52
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16357472
Urggg 馃槉
Look at Lian li stuff then but they're expensive聽
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16357663
1 hour ago, PDifolco said:
Urggg 馃槉
Alrighty
System Specs:
Mouse: Razer Viper
聽Other cool tech:
Dji mini 3
Flight hotas x52
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16357739
In my opinion, the new Artic聽is worth your money for sure, you can find it between $80 to $120 and the performance is top tier, by the way it comes with non-a-rgb and with a-rgb 馃槈聽 ( I just installed mine and it's a beast, it manages 160 to 180 watts and it holds it under 70c )
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16358280
Actually, EK Elite and DC Mystique are better. In the US, the LF3 is on sale till May for under $100. You can find the DC LS720 or LT720 on sale under $150, and it's only slightly lower on the list than the EK and Arctic. The LS had plenty of ARGB. There are many great AIOs out there, and not a lot of problems with leaking.
Don't waste money on the LF 2.
Nowadays, the big problem is an AIO clogging up with debris or biofilm. I think it was Snaxan on YT that did a video about how to drain a loop to get the debris out.聽 She's very talented. To stop biofilm or remove debris, make sure to buy an AIO with a fill port. To kill biological life, you can either add a biocide or a strip of silver can be anchored inside.聽
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 馃槈 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.馃お馃槀
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16358531
Yeah but can it support a 5800x?
System Specs:
Mouse: Razer Viper
聽Other cool tech:
Dji mini 3
Flight hotas x52
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16358672
It supports AM4 & 5. I suggest you make sure your mobo is not on the incompatible list tho.
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16358797
Fully agree with RevGAM on this. A big thing to consider with the AIO route is longevity. A custom loop, even just for the CPU, can be expensive, so I wouldn't push you to go that route, but having a drain/fill port for simple preventative maintenance is always nice... Not that a pair of scissors and a fitting cant 'add' a 'drain port' to anything you want.
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16358839
1 hour ago, PROZACTv said:
I have it with the r9 5950x and it pushes 175 watts
Sweet...
System Specs:
Mouse: Razer Viper
聽Other cool tech:
Dji mini 3
Flight hotas x52
https://linustechtips.com/topic/1563393-liquid-cooling/#findComment-16359289
