2 minutes ago, J03tz13l said:
I recently purchased an rtx 4070 super and can't put the 12 pin gpu cable all the way, even with extreme force... Is it normal?
Make sure its the correct way.  My 12pin goes in the other way ( Upside down )
You need to look inside the connector on the GPU side to ensure you weren’t crushing a pin.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
9 hours ago, Salted Spinach said:
If its a 12 pin adapter that came with the card, can I know what model it is?
It came with an Asus Dual RTX 4070 Super. However It has NVIDIA branding on the cable and not any Asus branding, so it may be NVIDIA original. I managed to enter it after using extreme force, even tho I almost broke the card or motherboard...
