cpu overheating and computer crashing
Go to solution Solved by PhasePenguin07,
I fixed it basically the bracket to the cpu cooler was broke so I got it fixed and the cpu went down to 26 with no more crashing
Simple- My games keep crashing and my cpu is overheating and the bios says it is at 70 degrees at lowest I changed the thermal paste and cleaned the radiator well my games still crash and sometimes my computer I even tried repairing the games but it didn't work and it is still above 70 degrees
Long rambiling Story without punctuation- My rgb for my cpu cooler wasn't working so months after I order something to hopefully make it work well when I try to plug it in it doesn't work so I give up and I gave up well when I went to plug back in my cpu cooler I plugged it in to cpu opt well next day I try to play a game my game crashes and I try multiple times well I try to repair the game thinking it is that and it crashes but this time my entire pc turns off well I go to my bios and see my cpu is now all the way at 70 degrees at lowest and I try to fix it by replacing the thermal paste and cleaning the radiator out and still crashes and high temps so I don't know what to do.
Specs-
64 bit (pretty sure)
Motherboard-x570 aorus elite
Graphics card-amd Radeon rx 7600
Cpu- ryzen 5 7600
Ssd-samsung 990 pro
Ram- trident z 5 ddr5 6400 32 GBx2
(i don't know if I need the exact information but gave it just in case)
Cpu cooler- artic liquid freezer III 360 A-RGB
https://linustechtips.com/topic/1563230-cpu-overheating-and-computer-crashing/
Specs-
Cpu- ryzen 5 7600
Ssd-samsung 990 pro
70c is still within safe operating temparture for the Ryzen 7600, its not overheating at all.
Its actually designed to hit 95c as a set point, it WANTS to hit 95c and stay there before limiting power or clocks.
I doubt its crashing due to CPU overheating. What power supply do you have? Be specific.
70c in bios aka not doing anything. That is NOT normal
Op try checking if everything is plugged in properly and that both the PUMP AND FANS are in.
