Surface Pro 9 lagging after waking from sleep after SSD upgrade
Solved by mrkvchm,
I think I figured it out. I was barking up the wrong tree thinking the SSD upgrade caused the problem. A user on Reddit suggested Win+Crtl+Shift+B to correct the issue when it was lagging, which totally worked. So I used DDU to nuke the Intel graphics driver and let Windows Update reinstall it and I haven't had an issue since.
Featured Topics
realfireguy ·
Posted in Graphics Cards0 -
Winterlight ·
Posted in Phones and Tablets1 -
3
ineedhelp.2145 ·
Posted in General Discussion0 -
1
atxcyclist ·
Posted in Home Theater Equipment1 -
1
2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
