Hello I have problem with my internet.
It doesn't work for up to 6 minutes (or even more) after start up.
In those 6 minutes you can see in the task menager ethernet shows up and disappears like in the video attached.
The question is how can I fix it?
https://linustechtips.com/topic/1562566-question-about-internet-problem/
This is either going to be a driver issue or hardware. First, I would download the current ethernet and WiFi drivers(if it has WiFi) for your system. After insuring they are downloaded go into device manager and uninstall the ethernet and WiFi drivers for the system, select the optional checkmark box to delete the driver software as well. Once uninstalled, use the driver installers you downloaded prior and reinstall them.
If that doesn't fix the issue and it's only ethernet that has a problem you can try a bios update if applicable.
That's it for software, so if it's still having troubles your ethernet port is kachowed.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Great advise, I would also try booting a usb os (Ex. Slax Linux) and see if the network works on there. That will make sure it is a windows problem not a hardware problem.
