So i recently sleeved my 24 pin and im wondering how i can tell if i put the cables back in right. The manual only has the diagram for the mobo side and its a strider 1000 watt ST1000-P. I am 90 % sure its done right but i dont want to mess up my system.
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/15625-power-supply-cable-testing/
Use a voltage meter and change it to the mode where when the two things touch together they create a beep. Forgot the name of it. Just use this function to test if the location of the wires matches.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/15625-power-supply-cable-testing/#findComment-175434
so test between the power supply and the cable? should the one side be plugged in (cable to mobo/ cable to PSU).
https://linustechtips.com/topic/15625-power-supply-cable-testing/#findComment-175553
Just put one needle on one location and the other needle on the same location to see it it beeps. If it beeps, it means that it is the same cable. You shouldn't need to plug it in. You are just making sure that the locations of the pins coming from the psu cable are the same as the wire where you plug it into the motherboard?
https://linustechtips.com/topic/15625-power-supply-cable-testing/#findComment-175605
thanks man
https://linustechtips.com/topic/15625-power-supply-cable-testing/#findComment-176086
thanks man
No problem. :) Planning to post some pics of your sleeved cables?
https://linustechtips.com/topic/15625-power-supply-cable-testing/#findComment-176212
no they are quite mediocre, i am planning to re-do them when i have the time and money. (it was my first time)
https://linustechtips.com/topic/15625-power-supply-cable-testing/#findComment-177653
