ID cooling SL360 Fans
ralphlim35
Need some help with this I'm not sure with these fan it has a 3 pin RGB header and my motherboard (MSI b450 plus gaming) has only 4 pin rgb header if im correct. can I plug it there or I need a 3pin to 4 pin adapter? read some stuff online that you shouldnt connect 3 pin to 4pin rgb headers because of the different wattage? and it could lead to breaking the lights of the fan. Im not really sure about this. hoping you guys could educate me on this
3 rgb pin is 5V, 4 pin rgb is 12V, youll fry the LEDs if you plug the 3 pin into the 4 pin, you can get an rgb hub to plug the fans into
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Would this work ID Cooling HA-02C ARGB Fan Hub
I dont think so as it still requires a 3 pin cable for the rgb data cable
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Helloo i have a follow up concerns my pc smell like burnt plastic when i turn it on at first i thought it was nothing and then my family kept on saying that it really smells
it seems to be coming from my AIO
i unplug my cpu fan from the AIO and the smell was gone
search about it online some say the power usage of the fan  check on it on the BIOS it was running 1400 rpm is that to fast should i lower it into what im not really sure i this area
Try unplugging the lights only and see if it still smells.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
The rgb lights are not plug in
And when the lights aren't plugged in, there is no difference in smell, or it's better (or worse)?
