Thoughts on build plan?
Go to solution Solved by venomtail,
19 minutes ago, TatamiMatt said:
I'd pick. For £60 it's good and will serve well for a pupil and their low end machine. People could argue bronze hurr durr not as efficient but most kids will waste more money by forgetting to turn off their PC than the pennies you'd save a year by going with a better rated PSU. For £8 more 750W is also valid, easier to upgrade down the line to lets say a hungrier GPU.
Maybe pick 750W version. Still the cheaperst.
Budget (including currency): ~£800
Country: UK
Games, programs or workloads that it will be used for: Gaming and light school work
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Already have case but a decently major upgrade so most parts arent usable in new build with the exception of SSD which will be transferred over but another SSD is wanted as current one is full
PCPartPicker Part List: https://uk.pcpartpicker.com/list/8pTzgB
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (£189.98 @ Amazon UK)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£149.99 @ Amazon UK)
Memory: G.Skill Trident Z5 Neo 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£128.99 @ Ebuyer)
Storage: Western Digital Blue SN580 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£59.99 @ Ebuyer)
Video Card: PowerColor Fighter Radeon RX 6650 XT 8 GB Video Card  (£239.99 @ Ebuyer)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£104.49 @ Amazon UK)
Total: £873.43
Generated by PCPartPicker 2024-03-11 07:59 GMT+0000
Looking to keep current build as close as possible to what it is currently is but maybe cut costs if possible? Thinking about mATX board but not sure if buyer wants as they have an ATX case currently
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/
You can do a fair bit of cost cutting. Replaced SSD but even cheaper ones exist like ADATA that should still be somewhat good enough. Might recommend adding a cheapo AK400 cooler. Sure some £20 extra but it'll at least be quiet. For many people, when they hear nothing = premium.
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£105.95 @ Amazon UK)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£56.19 @ Clove Technology)
Power Supply: Deepcool PK750D 750 W 80+ Bronze Certified ATX Power Supply  (£63.70 @ NeoComputers)
Total: £805.80
Generated by PCPartPicker 2024-03-11 08:32 GMT+0000
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346952
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£149.00 @ Computer Orbit)
Memory: *ADATA XPG Lancer Blade 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£108.66 @ NeoComputers)
Power Supply: *Gigabyte P750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£81.66 @ NeoComputers)
Total: £339.32
Generated by PCPartPicker 2024-03-11 08:36 GMT+0000
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346953
Not sure if either of you are from the UK but have you had any experience with the above mentioned sites?
Could go for a cheap cooler but my cousin (the buyer) is still in school and doesnt have an income so he'll be sticking as close to £800 as possible, but im willing to supplement some of it myself for him if he cant afford (im also saving for a holiday and a ring so the less spent by me the better)
The reason i chose the WD SSD is because its from amazon and ive never used clove tech, i originally had the P3 Plus in the build but SN580 was only 3 quid extra EDIT: P3 PLUS has £4.80 shipping from clove, so SN580 will actually be cheaper
If choosing between PK750D @ £63 or P750GM @£81 what would be the preference EDIT: Both these PSUs have no couriers that deliver to NI
And the mobo is £1 extra from amazon so that should be fine to stick with EDIT: Orbit is fine shipping wise and is free so ill order ADATA RAM and mobo from there as itll save a few quid
To add, usually sites like orbit, scan, neo computers etc are cheap shipping to mainland UK but paid shipping to Northern Ireland (where i live) so it might actually be cheaper if its more expensive but from somewhere that offers free shipping, not sure if these sites offer free shipping or not but its something ill check out
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346958
New more discounted list, any other changes?
PCPartPicker Part List: https://uk.pcpartpicker.com/list/xFcRbL
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (£189.00 @ Computer Orbit)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£149.00 @ Computer Orbit)
Memory: ADATA XPG Lancer Blade 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£109.00 @ Computer Orbit)
Total: £851.47
Generated by PCPartPicker 2024-03-11 08:59 GMT+0000
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346964
We've got good consumer protection here. Buy from sites you don't trust with a credit card, the slightest trouble when they don't deliver you can always claim back money cause well, it's not yours.
NI shipping will be a struggle. Heard some people say it's cheaper to ship from Ireland or EU than from GB.
I'm not a fan of you choosing the £105 Corsair PSU. At least go with a cheaper option from one of your sellers (I just realised choosing shops doesn't come across on links).
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346974
No, not a fan of the Corsair PSUs price with the build, tis more of just a placeholder for now, how is the corsair CX (2023) range? I know the CX range isnt too bad but is the 2023 revision an improvement?
Possible options:
Gigabyte-UD750GM
Corsair RM650
Corsair CX650 (2023)
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346986
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346991
CX750 from orbit is £65 so cheaper again, can go for that alongside mobo and RAM
PCPartPicker Part List: https://uk.pcpartpicker.com/list/9scGRK
Power Supply: Corsair CX (2023) 750 W 80+ Bronze Certified ATX Power Supply  (£65.00 @ Computer Orbit)
Total: £811.98
Generated by PCPartPicker 2024-03-11 10:02 GMT+0000
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16346993
9 minutes ago, Why_Me said:
Country: UK
Total: £873.43
if they don't need the iGPU
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (£36.29 @ Amazon UK)
Motherboard: *ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  (£127.08 @ Amazon UK)
Memory: *TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£105.95 @ Amazon UK)
Storage: *KIOXIA EXCERIA 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£44.86 @ Clove Technology)
Video Card: PowerColor Fighter Radeon RX 6700 XT 12 GB Video Card  (£339.99 @ Ebuyer)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£89.99 @ Amazon UK)
Custom: 7500F (£116.00)
Custom: Used Corsair AIR 540 (£10.00)
Total: £870.16
Generated by PCPartPicker 2024-03-11 10:26 GMT+0000
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16347000
Where did you find the 7500F? To my knowledge i dont think i can get one here
https://www.awd-it.co.uk/amd-ryzen-5-7500f-six-core-5-0ghz-processor-msi-pro-a620m-e-amd-ryzen-ddr5-micro-atx-motherboard-cpu-bundle.html
Only deal i can find on it, though its not an awful one, £258.94 with shipping
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16347004
Total: £1040.95
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16347007
Total: £870.16
7500F is only a sensible option if you're in the US. Everywhere else they don't exist so have to ship from China and then the shipping costs outweigh the savings, often being more expensive than a 7600X and needing to wait a month or two whilst the latter will run better, can be a one day delivery and will very likely cost less in the end (don't forget import tax).
Realistic 7500F price is like £200+~ including shipping and import. Just not worth it.
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16347030
Total: £811.98
Grand, i think im going to go with this and if he wants the upgrade I told him i can lend him £100 for as long as he needs if he wants to go for a 6700XT for the extra performance and VRAM, thanks guys!
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1562040-thoughts-on-build-plan/#findComment-16347033
