23 minutes ago, 4eyeguy said:
PC Partpicker
My pcp says that my cooler has a compatibility issue with my mobo and may need a mounting bracket. Do I need to worry about this or not?
Thanks!
You might have to replace the backplate the motherboard comes with (if any) with the one included with the cooler.
Should be fine!
https://linustechtips.com/topic/1561997-compatibility-issue/#findComment-16346731
