NZXT h6 flow
9 minutes ago, Squidzy18 said:If I get it for my $1900 build what additional fans should I put into it?
no need to add additional fans. it should be good without them
10 minutes ago, Squidzy18 said:Is the NZXT h6 flow a good case?
yes
10 minutes ago, Squidzy18 said:I was thinking all black hardware with white to light blue lights.
the p28 from lian li are quite good but they're not RGB. There's also the P12 ARGB PST 3 pack
11 minutes ago, Squidzy18 said:my $1900 build
What does your build look like and what are you using it for?
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($354.00 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard ($179.99 @ Newegg)
Memory: *Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($92.97 @ B&H)
Storage: Lexar NM710 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($104.99 @ Amazon)
Video Card: *PowerColor Hellhound Radeon RX 7900 XTX 24 GB Video Card ($919.99 @ Newegg)
Case: NZXT H6 Flow ATX Mid Tower Case ($109.99 @ B&H)
Power Supply: Deepcool PX850G 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Newegg)
Total: $1897.82
Generated by PCPartPicker 2024-03-04 08:26 EST-0500
