hi i updated my cards graphics drivers a while ago an ever since then my gpu has been running colder all of a sudden , fans are fine , no performance decrease ,the only thing ive done hardware wise was disassemble my pc entirely ,redo everything ,took everything out ,cleaned it ,plugged it back in after repasting cpu an now 2 of my case fans have quit working an these are the fans that came with my case , i aint got any idea whats going on ive looked online  the pic below is my temps after a complete full day of playing rust normal my gpu is like at 75-77c and it hasn't gotten passed that point at all tbh even the cpu is running cooler ,but i repasted maybe the newest nivida graphics driver boosted its performance ? i haven't noticed a increase in that just that its running cooler all of a sudden
https://linustechtips.com/topic/1560555-gpu-suddenly-running-cooler/
Getting the dust out of your PC makes your heatsinks work properly, so it's likely just that.
You're also using HWMonitor which can often be inaccurate, so it could be that derping out too. HWiNFO64 is the much better hardware monitoring utility.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
I have yet to see any substantiation for this claim, except for maybe some niche scenarios where HWMonitor exhibits compatibility issues with certain hardware. Just seems like people are pushing certain preferences as fact, when it is totally unwarranted. It does offer more information(amongst other things), but it's not fair automatically jump to conclusions without having any real data to support it. The temperature readings are more than likely correct.
The "only thing" is pretty significant here. If your radiators, heatsinks, and fans had a bunch of dust in them, that definitely affects thermal transfer, and thus parts will run hotter. And the fact that you reapplied thermal paste can be a significant factor too. I highly doubt it has anything to do with the drivers, unless your clock speeds and voltages were reset(assuming overclocking was done).
The cleaning probably helped and maybe there was something in the new driver to make it run cooler. No need to worry if performance isn't dropping though. I wouldn't be complaining.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
1 hour ago, WolfOfValahalla said:
...disassemble my pc entirely ,redo everything ,took everything out ,cleaned it ,plugged it back in after repasting cpu an now 2 of my case fans have quit working an these are the fans that came with my case...
Maybe those 2 fans were somehow making it difficult for your GPU cooler? Were the dead fans replaced?
Unless you cleaned an amount of dust that had a significant impact on cooling
it was pretty clean even when i opened it ,the fans im currently working on replacing still need to order them i check my pc at least once a month to see if it needs cleaning and it never did it was running cooler after i updated graphics driver before i did a full cleaning
What driver revision are you currently running? And what games are you noticing the GPU is running cooler? Did you have a fan profile configured previously, and if so, is it still running with that profile?
driver vers 551.52 never had a fan curve set an ive noticed it on every game i play ,rust ,dayz ,escape from tarkov ,predator hunting grounds ,ark ascended everything an just so everyone else knows ,i have never overclocked as i dont know how to ,this is my first pc ever ive built myself an the second one ive ever owned my first gaming pc was a prebuilt i can also hop in a discord call if needed to explain things easier an maybe i can share screen so yall can see an tell me what to check ect
What driver version did you have previously? What temperature was the GPU at prior typically? Did the conditions of the room change at all?
forget which driver version an normally itd get up to 80c an no the conditions havent changed
