usb drive
Solved by Poinkachu,
41 minutes ago, mhs8484 said:i had some files on a usb drive and i downloaded widows installation media on it but i can find the files that was there before , can someone help me get my files back thanks
You mean you made a usb windows installer ?
Turning your thumbdrive into a USB bootable media usually consist of formatting the drive first.
So those files are gone.
