Budget (including currency): 3500 US
Country: US
Games, programs or workloads that it will be used for: I wanna stream FPS and RPG games
I already bought the case because it was the original reason i wanted to start building a pc.
https://linustechtips.com/topic/1560245-need-tips-for-build/
Seems like you should be able to fit a better GPU into a $3500 budget system.
Power supply is excessive.
You could probably use a board that costs hundreds less and not notice a difference.
128GB of RAM doesn't seem necessary for gaming and streaming, you're not doing workstation stuff.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334123
Screen grabs are difficult, especially on mobile devices. It also doesn't provide enough detail. Post the hyperlink found at the top of the build list or use the BB button and post a BB formatted list.
From the motherboard memory support page (bold added by me):
"Ensure that all memory modules are from the same validated memory kit. Do not mix DIMMs from different memory kits—even if they are the same brand and model (e.g., two DIMMs each from two different memory kits). Mixing and matching DIMMs can result in a failure to boot and compatibility issues. In particular, the stability of a system with mixed DIMMs cannot be guaranteed when XMP (Intel)/D.O.C.P (AMD)/EXPO (AMD)/AEMP/AEMPII is enabled. For example, enabling XMP (Intel)/D.O.C.P (AMD)/EXPO (AMD)/AEMP/AEMPII to speeds above DDR5 4800MHz or above DDR4 3200MHz could result in an unstable system."
The PSU is beyond overkill. An 850W ATX 3.0 compliant model is sufficient for most current GPU. Certainly more than enough for an RTX 4070 Super.
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334125
Sorry about that here's the link https://pcpartpicker.com/list/7hWVRK
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334130
i think ill switch it to a 4080 super
should i change it to 850?
what would you recommend for another board?
should i just do 64 or 32?
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334131
Consider a memory kit with EXPO profiles instead of XMP. https://pcpartpicker.com/product/pqcG3C/gskill-trident-z5-neo-rgb-64-gb-2-x-32-gb-ddr5-6000-cl32-memory-f5-6000j3238g32gx2-tz5nr
I'd suggest an 850W or 1000W ATX 3.0 PSU with native support for the 12VHPWR connector.
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334138
There is a lot of room for improvements. You can get a 4080S with this budget and you don't need 128gb of DD5 unless you want to do professional video editing, but then you'll need to change that CPU to a 13th/14th gen instead. because not only the X3D chips suck for production work, but also good luck getting 128gb and 4 sticks of RAM working with this processor.
I would opt for 32gb of CL30, 13600/13700K/13900K( if you're going to be doing any video editing and productivity, otherwise you can go with the X3D chip), And an Arctic LFII instead of the current AIO. The 990 Pro or the SN850x Black instead of the 980 pro. And your Motherboard pick is needlessly expensive. This would be a 4K gaming PC, but still pretty great for lower resolutions.
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334169
Country: US
Games, programs or workloads that it will be used for: Streaming RPG and FPS games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I already bought the case so I cannot switch it
https://pcpartpicker.com/list/m3djKX
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334664
Country: US
PCPartPicker Part List: https://pcpartpicker.com/list/LXZ4mD
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($349.00 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: ASRock B650E PG RIPTIDE WIFI ATX AM5 Motherboard  ($179.99 @ Newegg)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($117.99 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($169.99 @ Adorama)
Video Card: MSI RTX 4090 GAMING SLIM 24G GeForce RTX 4090 24 GB Video Card  ($1799.99 @ Best Buy)
Case: HYTE Y60 ATX Mid Tower Case  ($179.99 @ Best Buy)
Power Supply: EVGA SuperNOVA 850G XC 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $2932.84
Generated by PCPartPicker 2024-02-28 11:08 EST-0500
Better CPU, much better GPU, for less
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334669
Country: US
Don’t pay 1300 for a 4080 super. And don’t pay 300 for an aio
CPU Cooler: ARCTIC Liquid Freezer III A-RGB 48.82 CFM Liquid CPU Cooler  ($107.79 @ Amazon)
Motherboard: *ASRock B650E PG RIPTIDE WIFI ATX AM5 Motherboard  ($179.99 @ Newegg)
Video Card: *Gigabyte GAMING OC GeForce RTX 4080 SUPER 16 GB Video Card  ($1049.99 @ B&H)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.90 @ Amazon)
Total: $2084.65
Generated by PCPartPicker 2024-02-28 11:06 EST-0500
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334672
Total: $2084.65
he's right, with good parts you can save 900$:
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard  ($159.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($92.99 @ Newegg)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  ($909.99 @ Newegg)
Case: HYTE Y60 ATX Mid Tower Case  ($0.00)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Newegg)
Total: $1835.85
Generated by PCPartPicker 2024-02-28 11:16 EST-0500
Though not sure why you need B650E Motherboard
current PC:
PC configs I used before:
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334686
CPU: *Intel Core i7-13700 2.1 GHz 16-Core Processor  ($339.99 @ Amazon)
CPU Cooler: *Deepcool LT720 85.85 CFM Liquid CPU Cooler  ($109.99 @ Newegg)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($159.99 @ Amazon)
Storage: *Lexar NM710 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.99 @ Amazon)
Video Card: *MSI RTX 4090 GAMING SLIM 24G GeForce RTX 4090 24 GB Video Card  ($1799.99 @ Best Buy)
Power Supply: *be quiet! Pure Power 12 M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.90 @ Amazon)
Total: $2942.83
Generated by PCPartPicker 2024-02-28 12:08 EST-0500
https://linustechtips.com/topic/1560245-need-tips-for-build/#findComment-16334743
