Cooler for overclocked R9-5900X
DymOK
What will be better for an overclocked (PBO 160W+) R9-5900X: Thermalright Silver Arrow T8 with 2 fans or Arctic Cooling Liquid Freezer II 280mm?
My case is Fractal Design Node 804. Now with Thermalright Silver Arrow T8 and 1 default fan I am running 86-89C in Prime95 at 160W + Furmark on my RTX4070.
neither. The arctic liquid freezer III 240, since it's on a deal ($80 I think)
get the arctic liquid Freezer iii 240 or even 280 if you can fit it ARCTIC Liquid Freezer III 56.3 CFM Liquid CPU Cooler (ACFRE00134A) - PCPartPicker
ARCTIC Liquid Freezer III 72.8 CFM Liquid CPU Cooler (ACFRE00135A) - PCPartPicker
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
Well... I'm having shipping issues with Amazon and can easily buy the Freezer II at my local store.
How big is the difference between Freezer II and Freezer III?
for the 280 it's 2.5 degrees. If that doesn't bother you then go for the 280 LF2. I've got the 280 LF2 so just know that it has quite long tubes (one of the main reasons why I didn't use it in my itx build)
Current parts list
How much better will it be than Silver Arrow T8?
My Thermalright AIO works pretty good on my 5900X, but it is a 360.
Ambient is 18c.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
Either get that or the thermal right PA120SE or the PS120SE. They’ll defo be enough for it if you wanna go aio
The decrease in temps should be around 5 degrees
Current parts list
PA120 does not do as well as PS120 with 5900X. I have them both.
