RGB Help
1 hour ago, TheWiseWarlock said:So I have an ASRock mobo and I want to control all of my rgb with one software. I was wondering if the Thermalright Frozen Notte 360 ARGB works with polychrome sync and if the Zalman P30 case fans work with it.
If not, I would be fine with using a different software that also work with them and also work with the T-Force Delta RGB and ASRock steel legend 7600 for RGB sync.
thanks!
Hello... As long as the Fans on the Zalman Case don't use Molex Fans then I would say YES, The Case and the AIO should be controllable with the Pollychrome Software.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
