Advice - Corsair Commander Pro - CPU fan header
Solved by NorKris,
26 minutes ago, Scott Macbeth said:Hi all, just asking for advice on this, i have 6 Corsair fans 2 built in to my AIO, my MB is B550-F Gaming WiFi II. I recently bought a corsair commander pro to control my fans in software and i was wondering if i can control all 6 fans with it and leave the CPU fan header unplugged and still be able to boot my pc and if thats a viable option or should i have the 2 fans on the AIO plugged into the MB and control those in BIOS and 4 in cosair?
u go to the bios and uncheck the box for alarm if no CPU fan is connected
then u connect all the devices to the CMD Pro
or u connect the Pump to CPU fan and all the fans to the CMD Pro
