Hi all!
I took a hard drive from my friends computer to proove to Ubisoft that my AC4: BF game is not having a hard ware issue, but it was the game. So I plugged his Hard drive into my PC and booted up the PC. the game worked, unpluged the hard drive and plugged it in to his. Mine still works as I am posting from it but his PC will not display graphics once he gets to the log in screen. He sees the motherboard logo, and the windows boot logo, but nothing magor past that. He can see his cusser and sometimes the ethernet picture when shutting it down. Any ideas on what to try?
(I haven't logged in in years, I have to update this)
My PC Spec:
CPU: Intel i7-8700k @ 3.7GHz, Motherboard: , Memory: 16gb , Storage: , Storage: Crucial BX100 250GB, Storage: Seagate Barracuda 3TB 3.5" 7200RPM, Video Card: EVGA GeForce GTX 970 SC(x2), Case: Corsair C70 Green, Power Supply: EVGA SuperNOVA NEX750G GOLD, Operating System: Windows 8.1, CPU Cooler: CORSAIR Hydro Series H100, Optical Drive: LG Internal Super Multi Drive
https://linustechtips.com/topic/155883-hard-drive-issue/
hit F8 while booting then select repair my PC from the menu and load last know good configuration.  If that doesn't work you might try a windows cd and choose the repair installation option.  If that doesn't work you may have to take it to a local repair shop or re-install all together.
https://linustechtips.com/topic/155883-hard-drive-issue/#findComment-2077839
As in the windows log in screen? Try to boot from a recovery DVD/USB stick and repair windows. When you get to the log in screen try to unplug then plug the monitor back in that might work. If it still does not try to unplug the GPU and use the integrated one instead (assuming he has either of those).
Edit: When you plugged his drive to your pc from which drive did you boot from his or yours? If you booted from yours it might be a driver issue.
CPU: i5-3490k @ 4.0Ghz | CPU & GPU Cooler: Custom Watercooling Loop |  Motherboard: MSI Z97 GAMING 7 | Ram: Corsair Vengeance 12GB 1866Mhz | Graphics Card: ASUS R9 290
HDD: Seagate 1TBx2 + 240GB Plextor M6e | Case: NZXT Phantom 410 | Monitor: 2 Random 21" TVs
OS: Windows 10 Pro 64 Bit
https://linustechtips.com/topic/155883-hard-drive-issue/#findComment-2077842
We are trying something right now, Deleted the Nvidia Display driver.
I used it on mine as a stand along drive, and he does not have a DVD drive.
My PC Spec:
https://linustechtips.com/topic/155883-hard-drive-issue/#findComment-2077883
We figured it out... Just did a system restore.
My PC Spec:
https://linustechtips.com/topic/155883-hard-drive-issue/#findComment-2077984
