Help with PC build
Go to solution Solved by podkall,
A build like this with a x3D chip AM5 will get you long way:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($588.77 @ JW Computers)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($59.00 @ Scorptec)
Motherboard: Gigabyte B650M GAMING X AX Micro ATX AM5 Motherboard  ($279.00 @ Amazon Australia)
Memory: *Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($159.00 @ MSY Technology)
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($468.09 @ Amazon Australia)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  ($0.00)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($159.00 @ PCCaseGear)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.00 @ Centre Com)
Total: $1861.86
Generated by PCPartPicker 2024-02-18 00:11 AEDT+1100
Budget (including currency): $3000AUD
Country: Australia
Games, programs or workloads that it will be used for: Video editing, Streaming, Valorant
Other details   I want to use this build: https://au.pcpartpicker.com/guide/JLgXsY/enthusiast-amd-gamingstreaming-build  I only want to change the case to be this one: https://www.pccasegear.com/products/57867/fractal-design-pop-air-rgb-tg-clear-tint-magenta-core  Also do you think that I can use my existing video card, instead of getting a new one: https://www.centrecom.com.au/gigabyte-radeon-rx-7800-xt-gaming-oc-16g-graphics-card  Will this work out?
https://linustechtips.com/topic/1558487-help-with-pc-build/
that would open up quite the amount of budget for some good stuff in addition, yes you can use your current GPU, let me make a list
current PC:
PC configs I used before:
https://linustechtips.com/topic/1558487-help-with-pc-build/#findComment-16322654
Total: $1861.86
current PC:
https://linustechtips.com/topic/1558487-help-with-pc-build/#findComment-16322668
Total: $1861.86
Thanks
https://linustechtips.com/topic/1558487-help-with-pc-build/#findComment-16322902
Thanks
no problem, if you have any questions about the list don't be afraid to ask
current PC:
https://linustechtips.com/topic/1558487-help-with-pc-build/#findComment-16322906
