Hi there, i'm looking to buy a pc gaming/workstation for apps like After Effects, Cinema4d (redshift) and gaming. This is what i've currently come up with and wanted to check if everything in this build works together and if there is anything to be tweaked. Will be adding a rm1000x shift as well.
Link:
https://be.pcpartpicker.com/list/WgyrL9
Any advice would be kindly appreciated 😄
https://linustechtips.com/topic/1556967-first-pc-build/
Link:
Yeah, looks solid.  The 14700K is a good dual-use CPU actually.
You could probably cut corners and save a buck or two, but it's within reason.  Good stuff.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312667
In my honest opinion,  motherboard is an overkill, could get a cheaper one and add an extra SSD. What’s your budget? The rest looks good on first look, just don’t forget to buy a quality power supply as well.
>> Please consider tagging me (with a @) or quoting my reply so I can more easily get back at you! <<
Always happy to help!! 🤠
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312668
A few thoughts:
- The Strix 4080 is likely to be rather overpriced (no price showing).
- Your memory might be a little optimistic (I don't know what 14700K's achieve with 64GB, on average).
- I believe the freezer is quite thick, so you might want to double check it fits if you're going for the roof.
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312669
Thank you! Yeah i've done a lot of researching and just looking at benchmarks and this fit my budget/what it's going to be used for the best. Don't know a lot about PC's 😄
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312677
7 minutes ago, Tetras said:
A few thoughts:
I had a great deal on the Strix so i just went with that and it has great cooling which is handy as the system will be doing some overtime rendering stuff haha. I'm planning on doing a lot of 3D simulations on Houdini (3D app) and animations / simulations take up a huge amount of ram some people might even say 64 is not enough. The arctic should fit i went off of this youtube video (also love how this build looks).
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312682
What motherboard would be a good option? I just went off some benchmarks for the plus version but saw that that one had an "error" that it might needed a bios update that's why i decided to go with the pro as it supports 14th gen out of the box. This is my first time building a pc and don't really want to make it to difficult as i also don't know a lot about this stuff (just did a lot of research). I'm going with the RM1000X Shift as PSU (clearance should be enough)
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312687
That cpu is the equivalent of a 13900KS. If anything you want a board with rock solid VRM's.
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312690
Link:
That Asus board in your build comes with Asus EZ Flash 3 so even if that board doesn't have the updated bios you can update them without having to install the cpu and memory.
Three changes I see. First change is the case.
This case is optimal for the Arctic AIO's seeing how they are thick. This case has two settings ... one for watercooling and one for air cooling. That and it's the best case right now for the money. No need for the Shift with this case. Save your money and get the Corsair 1000e.
https://be.pcpartpicker.com/product/qP2WGX/lian-li-lancool-216-atx-mid-tower-case-lancool-216x
https://lian-li.com/product/lancool-216/
Second change I would make is the cpu. The unlocked version of that cpu can run hot when it goes into turbo boost. Look at the locked version of that cpu which gives you near identical performance without the heat issues.
https://be.pcpartpicker.com/product/7rXV3C/intel-core-i7-14700-21-ghz-20-core-processor-bx8071514700
https://www.intel.com/content/www/us/en/products/sku/236781/intel-core-i7-processor-14700-33m-cache-up-to-5-40-ghz/specifications.html
Third change is the RAM. Less expensive and G.Skill DDR5 is rock solid.
https://be.pcpartpicker.com/product/QJ3gXL/gskill-ripjaws-s5-64-gb-2-x-32-gb-ddr5-6000-cl30-memory-f5-6000j3040g32gx2-rs5k
https://www.gskill.com/product/165/377/1649234605/F5-6000J3040G32GX2-RS5K-F5-6000J3040G32GA2-RS5K
https://linustechtips.com/topic/1556967-first-pc-build/#findComment-16312704
