So it's stupid but I'm really new and I'm afraid that i might connect the wrong cable to the PC and monitor.
In the box i had a 2 pin power supply cable and a 3 pin cable, Which one goes to the PC (power supply is Corsair RM 650) and Which one to the monitor (Gigabyte G27FC). Please help me with this i know it's stupid:(
https://linustechtips.com/topic/1555531-need-help-with-power-supply/
11 minutes ago, jinxmaverick said:
I have two 2pin Cables in the box so do I even use the 3pin or no?
This in incredibly confusing.  What do the connections in the back of the PC and Monitor look like?
You have different male plugs, can you not match them to specific female sockets?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Just now, jinxmaverick said:
It came in the box the cable... The UK one and a EU one in the same box that's why I go confused
That's uncommon, but some manufacturers do that, or I've even had stores add them without asking because they know their model is intended for a different region.
3 minutes ago, jinxmaverick said:
If it's just the matter of region do I use there two One for the PSU and one for the monitor?
Is there no label to indicate which belongs to which? Is one of the cables higher gauge?
If there is a manufacturer, you could try googling it, if there are identifying marks you could check unboxing videos to see if you can find out.
It probably won't matter either way, but a PSU may have a beefier cable than a monitor.
both say 16A and i didn't find anything about which one goes where or is there a difference i tried checking for unboxings but nothing
it's like so basic and i think everyone expects it to be known:(
If both really say 16A then you should be fine with either. Even if not, you should be fine with either.
To be sure you could cut both cables and compare gauges but that would defeat the purpose.
Edit : just seen your 16A, you're fine (3500W max)
(that's still 3 pin, one is inverted)
Edited by leclod
If you don't quote us, we won't know you answered
PSU and monitor power cables are basically interchangeable, but the wire gauge and fuse (if there is one) can be different for devices with a higher power draw.
Ideally, you want the PSU cable for the PSU and the monitor cable for the monitor, but realistically it is unlikely to be a problem.
I try to avoid mixing my cables, but I'm sure I've done it more than once.
