Hi all,
I hope someone can point me in the right direction.
I've been experience Random Application Crashes. And Random Issues with anything running under WSL.
I cannot see any problems & my System it's self doesn't BSOD.
But after throwing Prime95 at it Prime is returning Fatal Errors.
I have no OC's and I am running everything stock.
My system is:-
CPU: I9 - 13900K
MainBoard: Asus Rog Strix Z790 -E
Ram : 2 X Corsair CMH64GX5M2B5600C36 Totalling 64Gb.
Graphics: Asus Tuf Rtx 4090
Hope for any advise.
Thanks,
James.
https://linustechtips.com/topic/1555328-strange-problems/
What are your temps under load and idle?
Have you ran any memory diagnostics? If not run Windows Memory Diagnostic and see if it finds any errors.
What are the rest of your system specs, Case, Cooler, Power Supply, etc?
What specific applications are crashing?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1555328-strange-problems/#findComment-16301900
My temps when Idling are 21 - 28C  & under load are :- 63 - 74 C
I've run Completed a Windows Memory Diagnostic & have no reported Errors.
Cooler is:- ROG Strix  LC2 360
Power Supply is:- Corsair HX1200
Case is:-  O11 DYNAMIC XL
Disk drives are :-
Sabrent M.2 NVMe 2TB Gen 4 - Boot Drive
Sabrent M.2 NVMe 4TB Gen 4
Samsung 870 Qvo 4TB
Corsair Force MP600 1TB -
Samsung SDD 850 Pro 512Gb
The Application's that crash / just go away from running are :-
Postman
RenPy
Discord
Teams
Vscode - ( But this might be my code ? )
I get Intermittent issues with the Cam not working properly when my systems boots and isn't available for face recognition to log in.
https://linustechtips.com/topic/1555328-strange-problems/#findComment-16302530
Can you post error message in event log from crashed applications?
Usually points in some direction.
Sounds like applications can run but won't hold for some reason.
Sounds familiar with my GPU
I'm jank tinkerer if it works then it works.
Regardless of compatibility 🐧🖖
https://linustechtips.com/topic/1555328-strange-problems/#findComment-16303285
