I just put together a used PC in a gigabyte B450M motherboard. When I placed my Ryzen 5 5500 in the computer (Which was new in the box) it would not post it just stayed on a black screen, also something to keep in mind the power button would not shut the PC off. I went to a friend's house and picked up his old Ryzen 3 3300 thinking I just needed to update the bios. The computer fired up with the Ryzen 3 in. I was able to put windows 10 on the M.2 drive and updated the bios to the latest date (12-25-2023) Version F65C. I updated windows and installed everything the way I needed. NOW the power button works when holding it down to turn the computer off. I also went into the bios before changing CPU back to Ryzen 5 to make sure it was updated. Same issues and now the power button will not shut off the computer. I have cleared the CMOS and tried booting using the one stick of RAM. Does this MOBO not support Ryzen 5 5500? The friend I got the old CPU from had the exact same board (MSI though) and I upgraded him to the Ryzen 5 5600 so now I am so damn confused. Specs below:
-gigabyte B450M motherboard  (used)
-Ryzen 5 5500 (New)
-DDR4 same 2 8GB sticks (new)
-1650 Super GPU (used)
-500 watt thermasmart power supply (New)
-1 TB Kingspec M.2
https://linustechtips.com/topic/1554986-any-help-would-help/
That is an safety feature of the PSU and will always work, i'd burn down that PSU if holding the pw button doesnt work.
That would mean the CPU is dead, have you tried the (if there) onboard graphics or a different gpu? ask your friend if he has one...
R7 7800X3D | RTX 4090 | 32GB 5200Mhz RAM | BeQuiet Dark Power 13 1000W | ASRock X670E Taichi | WD Blue SN570 2 TB | Samsung 960 Pro 1TB | FireCuda 2TB | 120 TB NAS |
Don't forget to mark the solution!
https://linustechtips.com/topic/1554986-any-help-would-help/#findComment-16299419
