I want to build a new pc for gaming and I have looked at parts that doesn't cost that much I just want to know if there is something better around the same price and if there would be a problem with the different parts
The parts that I found:
Power supply: DeepCool PF700 700W
CPU: AMD Ryzen 7 5700X
CPU Cooler: Noctua NH-U12S redux
Motherboard: ASUS Prime B450M-A II 90MB15Z0-M0EAY0 Motherboard, Black
Memory: Kingston Fury 16GB (2x8GB) DDR4 3200MHz CL 1
Storage: Crucial P3 Plus 2TB M.2 PCIe Gen 4 NVMe SSD, Up to 5000MB/s
GPU: ASUS Dual Radeon RX 7600 V2 OC Edition 8GB GDDR6
Case: Kolink Observatory HF Mesh black
https://linustechtips.com/topic/1554967-building-my-first-pc/
What's your budget?
get a thermalright PA120 instead for $34 Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler (PA120 SE-D3) - PCPartPicker
Get a b550 phantom Gaming 4/ac instead for $100
this psu is in the Tier E - avoid section of the tier list so steer clear of it
here's a build for $650 that'll perform the same
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($131.99 @ Newegg)
Motherboard: ASRock B550 Phantom Gaming 4/ac ATX AM4 Motherboard  ($99.99 @ Newegg)
Memory: *Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($33.97 @ Amazon)
Storage: *PNY CS1030 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Best Buy)
Video Card: *ASRock Phantom Gaming D OC Radeon RX 6600 XT 8 GB Video Card  ($239.99 @ Newegg)
Case: *MagniumGear NEO AIR (2023) ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: *Apevia Prestige 600 W 80+ Gold Certified ATX Power Supply  ($51.99 @ Amazon)
Total: $652.91
Generated by PCPartPicker 2024-01-27 10:08 EST-0500
And then one for $1100 that should perform a lot better
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($164.99 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: ASRock Z690 Extreme ATX LGA1700 Motherboard  ($129.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($55.97 @ Amazon)
Storage: *Patriot P310 960 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Amazon)
Storage: PNY CS1030 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Best Buy)
Video Card: *Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ Best Buy)
Power Supply: *MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Amazon)
Total: $1094.80
Generated by PCPartPicker 2024-01-27 10:07 EST-0500
Also use the template that's provided, it's there for a reason
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1554967-building-my-first-pc/#findComment-16299258
In order to make any comments we need to know, what your budget is, how much your paying for each of these parts, what country your shopping in, what games you play.
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1554967-building-my-first-pc/#findComment-16299261
