Remote desktop connection Steam problem
Go to solution Solved by Avocado Diaboli,
You could look into using Aster to basically run two Windows instances simultaneously on your PC and then use something like Parsec for him to remote into that Windows instance.
So me and one of my room mates have been playing diablo 4 a lot lately but we want to play together the problem is his pc does not have a good enough gpu to run the game so his only option is to play the game on my pc
So I had a good Idea
I would create his own user account on my computer and purchase his own copy of diablo 4 on his steam account completely separate from mine and he could just remote desktop to his user account on my computer and run the game my hardware should run 2 instances fine using medium settings.
So I fire up my steam and diablo 4 and he remote desktops from his pc to his user account on my pc loads up steam and.......... I get a prompt on my steam as soon as he launches his that mine is closing. So scratch that idea.
So next i try doing a virtual machine with virtual box but the max vram it will let me set for it is 256mb and thats not good enough for diablo 4. The only option we have is using a service called boosteroid but it is very buggy and limited. We are going to build him a gaming pc in the future but for now is there anyway to get it working at all with remote desktop connection or a virtual machine?
Dark Flash White case
ASUS Prime B760-PLUS Intel B760
Intel Core i5 12600kf
32GB DDR5 RAM
Nvidia RTX 4060
https://linustechtips.com/topic/1554936-remote-desktop-connection-steam-problem/
I wouldnt even call this an idea. RDP doesnt work for gaming. Windows also doesnt do multi-users at same time very well (infact it wouldnt even allow two users at once, be it one rdp and one local user). VirtualBox doesnt offer any sort of 3d acceleration or VGPU solution, so that is also not even going to work.
None of those things you listed will work.
And now a word from our sponsor: 💩
ℑ𝔣 𝔶𝔬𝔲 𝔬𝔫𝔩𝔶 𝔫𝔬𝔱𝔦𝔠𝔢 𝔭𝔢𝔯𝔣𝔬𝔯𝔪𝔞𝔫𝔠𝔢 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔴𝔥𝔢𝔫 𝔶𝔬𝔲 𝔥𝔞𝔳𝔢 𝔞 𝔰𝔱𝔞𝔱 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔬𝔳𝔢𝔯𝔩𝔞𝔶 𝔞𝔠𝔱𝔦𝔳𝔢, 𝔶𝔬𝔲 𝔞𝔯𝔢 𝔪𝔢𝔯𝔢𝔩𝔶 𝔩𝔬𝔬𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔱𝔬 𝔟𝔢 𝔲𝔭𝔰𝔢𝔱 𝔬𝔳𝔢𝔯. 𝔗𝔲𝔯𝔫 𝔬𝔣𝔣 𝔱𝔥𝔢 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔟𝔢𝔣𝔬𝔯𝔢 𝔞𝔰𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔥𝔢𝔩𝔭 𝔞𝔫𝔡 𝔰𝔢𝔢 𝔦𝔣 𝔶𝔬𝔲 𝔰𝔱𝔦𝔩𝔩 𝔫𝔬𝔱𝔦𝔠𝔢.
ᑐᑌᑐᑢ
  • 1 month later...
Thank you this worked very easily and flawlessly. Didnt even need parsec just let him use a display port on my gpu and some usb ports
32GB DDR5 RAM
Nvidia RTX 4060
