Is Mesh system good?
GhostzzU
recently ive been looking into mesh system because my ethernet extender is ass, i get low ping in games but really bad download when i use to get 200-300Mbps and now i get 10-50Mbps, i was wondering if mesh system is good?
ive been looking into this one specifically: https://a.co/d/28xIdfL
Yes, mesh WiFi typically works extremely well.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
A mesh system only really works if they're connected to each other. IF you're expecting the Mesh system to extend each others wifi signals then it's gonna be spectacularly terrible.
IDK what your current setup is, but if you're not hardwired to Ethernet extender or the extender isn't hardwired to the router, then it's gonna offer significantly lesser speeds.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Yes, mesh is good but has its limits. Every time your wifi signal is passed from one device to another you add latency. The best option is to have multiple access points hard wired to a switch. I do understand this isn't always possible if you don't have a way to run wires.
