So i want to buy this cpu its a AMD Ryzen 5 5600G - Ryzen 5 5000 G-Series Cezanne (Zen 3) 6-Core 3.9 GHz Socket AM4 65W AMD Radeon Graphics Desktop Processor - 100-100000252BOX
I was wondering if it would be fine running with my gpu i have a rx 570 i know it would probably bottleneck but i want to play like valorant and stuff and i was wondering if i would be fine
https://www.newegg.com/amd-ryzen-5-5600g-ryzen-5-5000-g-series/p/N82E16819113683?item=N82E16819113683
Its on sale so i was wondering if i should buy it
https://linustechtips.com/topic/1554101-i-need-help/
which cpu do you have now? It definitely won't bottleneck it. But at $128 it's not a great deal, cuz for only 7 bucks more the 5600 non x is there, and it's much better (just with no iGPU)
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293084
I have a ryzen 3 2200 g and i apologize im learning more about pcs what does no igpu mean
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293093
1 minute ago, Ineedhelpwithpcmyppls said:
no igpu mean
you're cpu can't display anything by itself (it needs a dedicated GPU)
Then I'd get the 5600 non x AMD Ryzen 5 5600 3.5 GHz 6-Core Processor (100-100000927BOX) - PCPartPicker
Total: £1040.95
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293096
Thank you but question when i install the cpu it wont mess up like my gpu would it ? Cause i know my gpu sucks i feel like the cpu would overpower the gpu
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293112
no it won't
it's better to have a gpu bottleneck rather than a cpu bottleneck so don't worry
Btw you might need to update your bios to install the new cpu
Which motherboard do you have?
Total: £1040.95
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293119
7 minutes ago, filpo said:
no it won't
My motherboard is a prime b450m AII
Its not the best motherboard but it gets the job done
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293128
I'd update the bios then
Total: £1040.95
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293134
4 minutes ago, Ineedhelpwithpcmyppls said:
Where would i get that at
Look at classifieds sites like fb marketplace
Theres basically no risk since cpus dont up and die on you compared to mobos where you may run into issues if you are unlucky
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293148
I linked it above (new) but look on fb marketplace an ebay
Update the bios to install the new cpu correct ?
Yup, do you know how to do that?
Total: £1040.95
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293149
Thank you ill look at fb marketplace and ebay
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293160
Yes i believe you have to spam delete right ? While pc is turning on
follow this guide
Total: £1040.95
https://linustechtips.com/topic/1554101-i-need-help/#findComment-16293162
