Budget (including currency): 1000 cad
Country: Canada
Games, programs or workloads that it will be used for: Vr games Eg. vail gaming eg. . Cs2
I already have most of the parts list complete, I just want some help to see where I can spend more/less
https://pcpartpicker.com/user/superboss888/saved/#view=WJmkwP
https://linustechtips.com/topic/1553237-gaming-pc-build-finalizing-help/
Country: Canada
permission denied
Country: Canada
Hello... I was looking over your list and I think this one would do you much better. Please let me know what you think.
I was able to move you from a Gen3 M.2 to a Gen4 M.2 for much faster Speeds. I switched the Case so that it has all the extra Fans you will need. The Corsair 5000D only has 2 and it is way too pricey. Everything else that I changed was so that it could all fit into your budget.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://ca.pcpartpicker.com/list/7dFPYN
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($189.00 @ Amazon Canada)
Motherboard: ASRock B550 Pro4 ATX AM4 Motherboard  ($90.71 @ Vuugo)
Memory: TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($49.97 @ Newegg Canada)
Storage: TEAMGROUP MP44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.97 @ Newegg Canada)
Video Card: MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card  ($394.50 @ Vuugo)
Case: Montech X3 Mesh ATX Mid Tower Case  ($79.98 @ Amazon Canada)
Power Supply: Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Canada Computers)
Custom: Thermalright Assassin King 120 SE ARGB CPU Air Cooler, AK120 SE AGRB, 5 Heatpipes, TL-C12C-S PWM Quiet Fan CPU Cooler with S-FDB Bearing, for AMD AM4/Intel for AMD AM4/Intel 1700/1150/1151/120  ($24.99 @ Amazon Canada)
Total: $1009.11
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
