Hey,
So about a couple of months ago, my games started freezing randomly while playing games. Nothing too annoying just some random small freezes that happen from time to time.
I didn't think much of it until I tried playing a game a month ago and it was unplayable. Multiple 5-10 second long freezes and such. I thought maybe my pc needed to be cleaned. I was able to clean the CPU but not the GPU (we don't have compressed air here in my country so the only thing I could use was a balloon pump thing you use for your camera). Then afterwards it started getting much worse. Other games that would load perfectly are now going on "not responding" for a bit before actually loading the title screen. For example, Genshin. Valorant takes me 5-10 mins to get past the intro screen and other games are having freezes as well. All where my gpu percentage goes from whatever it's at, to 1%. I tried reinstalling drivers, cleaning as much as I can, repairing system files, fragmenting my hard drives . Nothing has worked. What do I do.
https://linustechtips.com/topic/1552984-need-help-with-gpu-issues/
15 minutes ago, leclod said:
Hi,
Before cleaning you should have checked your temps. No excess heat => no need to clean.
Maybe give us a list of your hardware ?
Sure thing:
Ryzen 2700x
RTX 2060 6GB Msi
16 GB RAM Corsair DDR4
Cooler-Master PSU (Unfortuantly dont remember which one exactly)
ASUS PRIME B450M-A Motherboard
I assumed it might have been because it wasnt clean...its beyond dirty because i have no way of getting the dust in between the parts. Vaccums are a big nono supposdly, and compressed air isnt a thing here so the most i could do was a general wipe of the outside.
9 minutes ago, Azzazy698 said:
258 SSD Kingston C Drive (Used for windows and essential programs only)
2 TB HDD BarraCuda 3.5 (Games and everything else)
Ok, check the SSD health with CrystalDiskInfo.
Did you try to optimise it using the Windows tool (next to the defrag command) ?
Did you try to flush the cache, not sure if you have a tool for that (I do) ?
How full is that drive ?
Could it be you get your RAM full ? do you leave browser tabs open and then some ?
Edit : that's weird 🙂 ! got the answer before the question
Edited by leclod
If you don't quote us, we won't know you answered
Sorry for the late reply,
I've optimised both drives and i think i flushed the cache. The C drive is 80% filled while the D drive is 75% full.
My RAM is alright most of the time. It's not full from what Windows says.
Thinking this might be a gpu issue, might have damged it or it cant keep up with the rest of the pc because of the dust inside...any thoughts are appreciated!
On 1/15/2024 at 7:34 PM, Azzazy698 said:
Hey,
This could actually be a storage drive issue.
What are these games stored on?
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
