Hi all,
I bought a MSI mag z790 tomahawk max wifi motherboard recently. On building the CPU would not sit in the slot.
On further close inspection I found an out of place pin by a bad join (see picture)
Only problem is I think other pins have very slightly bent by the CPU not sitting down, is this rma worthy because of the poor manufacture or will the store blame me for bending pins?
https://linustechtips.com/topic/1552825-rma-help/
14 minutes ago, Berryboy said:
Hi all,
To me this would be an easy RMA. There is no way your CPU did that even if you put a lot of pressure on it.
Looks like a fault during production. Send it back asap.
https://linustechtips.com/topic/1552825-rma-help/#findComment-16283660
