Sorry guys but it seems I cant be spared. From my previous posts you can deduce that my RAM wasnt running fine until ive bought my new sticks, Corsair Vengeance CL16 3600mhz. Ive had them for 2 days and played Warzone with no end and didnt have any issues at all, even had some FPS gains bc they run at their speed which they are supposed to. Also did the 3DMark stress test and no issues, until today. Just at random my pc crashed again and checking the dump file hinted at a faulty driver. After the crash my PC wouldnt boot with XMP on and I just set the timings and voltage manually (this time when setting it manually it runs at 3581, bc I forgot to set it to Gear 1 in the post before). Now my PC boots and I hope it will run stable but im unsure of what causes the crashes. Ive considered a clean Windows install but I had just done that 3 months ago so yeah. Any ideas what could help?
https://linustechtips.com/topic/1552747-ram-problems-again/
2 hours ago, scottyseng said:
Have you tried running a ram test like memtestx86 or a very hard CPU test like Intel burn test, occt, or linpack extreme?
It may be a bad ram kit, it happens.
Does the ram kit have a qvl? Does it list your motherboard?
thats the thing, ive had crucial ballistix ram before and it was less stable than the corsair one so i bought the corsair one. The Crucial one is on the QVL but still runs worse than the corsair one, which isnt on the QVL due to it being released after the QVL was made. And no i havent tried doing any memory test besides the Windows one.
https://linustechtips.com/topic/1552747-ram-problems-again/#findComment-16283184
