Replacing a 240mm aio with a 240mm loop
HardStroke
Is it worth it? the loop will be used after I upgrade my cpu, will prob just have to get a new cpu block for newer sockets
I've got a 5 year old Corsair h100x on my overclocked 10900k and I was wondering if its worth the effort
I'm not that sure because at the end of the day they both have a 240mm rad so idk
a 360mm rad wont fit at the top so It can only be front mounted
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
Not worth it imo, only advantage is a stronger pump and more water to slow coolant heatup...
Plus you'll have to buy everything except fans, you won't be able to reuse the block nor cables nor the rad
Getting a new case + 360 may be cheaper and will be more efficient
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Not even close to worth it.
Get a 360mm and case like said above if you want best cooling reasonably.
Doing a custom loop for less than the absolute best parts is just for fun, IMO.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Yeah I just compared the prices
Its 150 bucks for a Galahad 2 Trinity and 530 bucks for a loop kit lol
Thought that it could be nice to have a loop but its still really expensive
There are part from aliexpress from a well known Chinese company and its was cheaper, what about that?
The intension of the loop is to push the 10900k to 5.2GHz. The silicon is good enough but my current aio is not plus when I do decide to upgrade my cpu the loop will still be usable, Ill just need to get a new cpu block
Diy you can do it for 200.
But like a loop isnt magic. The only real difference is pump force and that isn't even that much of a deal.
The only advantage I can see is that, if you build it right, you'll be able to expand it for future needs. If all you're doing is replacing with a like system. It's a waste, so build it to be upgradeable/expandable.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
