Need help with the cpu fan
Solved by TatamiMatt,
2 minutes ago, MontyAthenas said:Hi, I purchased recently a si-100 from thermalright and the fan that it includes is an argb fan, I have an argb and pwm hub for all of the other fans that are in my case (they are 2 thermalright tl-c12c-s), and my motherboard (the b550i aorus pro ax) only includes one argb header, so I wanted to know if I could plug the 4 pin connector of the cpu fan into the cpu fan header and plug its argb 3 pin connector into one of the argb headers of the argb hub that no other fan is connected to
The argb and pwm hub is this one btw:
Dont see any reason you couldnt, just make sure its 3 pin to 3 pin or 4 to 4, dont mix and match them
